Sponsored by: Auxito
Crank Sensor Leak
Old Sep 11, 2010 | 10:47 PM
Lime1GT's Avatar
Lime1GT
Crank Sensor Leak
02 F150 4x4 5.4L. For those who have addressed crank sensor oil leaks; is it normally the o-ring to the block or the sensor leaking internally through the connector that leaks? Maybe both? The mount bolt looks close to the A/C compressor. Will it have to be moved to remove the sensor?
