Sponsored by: Real Truck
frort end swap
Old Sep 11, 2010 | 06:34 PM
lowbudget2's Avatar
lowbudget2
frort end swap
Hi Guys is the 1999 running gear the same as a 2001. Can I just bolt this stuff in?
I`ve been reading about the dana 60 swap to my early 1999 f250 and am confused. I have to change both front and rears because I have 3.73`s and I have access to a 2001 v10 complete truck. I think it has a dana 60 but I`m not sure. It has 4.30`s gears but the front axle sticker says d273d and I can`t find this code. Also I will need to swap my stuff back into the 01 so does the rear and front diff`s just bolt up or do I have to modify. I know about the trackbar and bracket , and the sway bar. Will I just have to swap drivelines up front. The 01 has front antilock and the99 doesn`t so I will have to leave that on the 01 so where do I seperate the stuff (hub and rotors stay on the old vehicles or swap from knuckle out). The front lug bolts are bigger than the 99 does this mean anything?
Thanks in advance
Barry
