First Oil Change VIDEO
#31
#34
Filling oil filters is a matter of personnal choice. Many diesel engines use a much larger or even two oil filters and no mention is made in the manual about prefilling. Also there is no way to prefill the filters on the 6.0 or 6.4 or the Mercedes diesels that use the same filter arrangement and no one seems to lose sleep over that.
#36
I just checked the Fumoto site. Application info is cryptic. Anyone know anything about these for our new engines? Lots of folks complain that the oil shoots out forcefully almost horizontal for a couple feet with the factory 1/4 turn thing. Just wondering if this would make life easier.
Oh, Mr. Epic, I can't rep you anymore or I would have.
#39
You should always fill the filter when doing an oil change. At least to within an inch of the top of the filter. Let it set in the box it came in for a little bit so the oil soaks into the filter and then top it up. My 7.3L takes about 1.5qts.
Not only does this help get quick oil pressure, it also wets the the filter so the high pressure oil doesn't shock a dry filter.
I haven't changed oil in the 6.7L yet but it looks like about the same size as the 7.3L.
Just remember when you fill the filter to add that to the total amount of oil you put in the engine.
I hope this helps
I hope this helps
#40
#44
on
No magnet and I wish it did. And there's no way to add a magnet on the bottom of the pan because it is plastic, (er, poly compound). Seems like we just have to rely on that very expensive filter to do its job.
#45
