1/2 vs. 3/4 ton
I currently have an 88 F150 4x4 5.0 w/AOD,150 K mi. Truck has been very good to me, but it's starting to age and there are numerous little things that don't work. So I'm looking for a new (or pretty young) truck this year.
My hauling/towing duties are nowhere near that of Chet's. Mostly, I'd be towing a 5,000# boat/trailer, a utility trailer with a tractor that would be about 4500# tops. There have been times where I had to make other arrangements to tow something larger such as a skidsteer.
I'm leaning towards the SD instead of the F-150 for a few reasons. First, a little more capacity for the "bigger than usual" loads. Second, if I get new, I can get a 6 spd with the 5.4L. Third, the SD just plain looks better to me.
Thanks for any feedback.
Another option you do have is the F150 7700, this truck has a 7700# payload and comes only with the 5.4L. The only problem I forsee with this is that they only come in automatic and it sounds like you want a standard.
Good Luck and enjoy whichever truck you pick.
It only comes with the 4sp auto, 5.4 v8, and 3.73 or 4.10 rears. The maximum payload is within a few pounds of the F250 SD with the same engine/trans. Tow capacity is listed at 8400# regardless of the towing method.
I haven't had any complaints except fuel economy. This truck has done everything I asked of it except match the fuel economy of my beater Festiva (35mpg
). My driving is country backroads and interstate highways. I get on average about 14mpg empty and if I load to the legal limit I drop to about 8 or 9mpg.
My next truck is going to be an F350 SD srw with the new 6.0 and TorqueShift trans. I'm going this route mainly because I anticipate my hauling needs to exceed the limits of the current truck, plus I want a SuperCab and I want the better fuel economy of the oil burner.
Bob
ps. For the record, my 2000 F150 is the base line Work Series. If I had gone with a F250 SD in the same trim level (what trim?
) the pricing would have been the same MSRP although the F150 had a rebate and the F250 didn't.
