removing window regulator
Old Sep 11, 2010 | 11:14 AM
ejmaso's Avatar
ejmaso
Hello,
Step three in the 1946 service manual instructs "Remove the link stud lock from each stud, and remove the regulator links from the window channel." I will try to attach a picture of the innards---
. I need advice about what to remove from what, and how this fitting is fastened.
Thanks guys,
Tom in Terre Haute
Old Sep 11, 2010 | 11:37 AM
whateg01's Avatar
whateg01
You need to upload the pic to your gallery or to an image hosting site, like Photobucket. Then link the pic from there. All I see in your post is:
Dave
Old Sep 11, 2010 | 02:28 PM
ejmaso's Avatar
ejmaso
Thank you, Dave. The picture displays now.
Old Sep 11, 2010 | 07:49 PM
46fordtruck's Avatar
46fordtruck
I always just unscrew the reg from the door, slowly let the window and the reg slide down until you can see the arms and channel through the access hole, then just wiggle the reg around until i can get the arms to just slide out of the window channels at the bottom of the window frame. They are quite easy to slide out, no need to remove any stud locks. Thats how I have always removed the windows and regulators.
Old Sep 13, 2010 | 09:02 AM
COMPLIT1107's Avatar
COMPLIT1107
Gary nailed it.. Just remembered a rookie question from before. PUSH the reg inside the door, so the handle post is inside as well...
Good luck.. PS. keep window frame up in window opening, don't let it drop inside door. After the reg is disengaged, turn curved part of frame 90 degrees up into window opening and out of side channels, then slide window up and out through window opening.
chris64
45
Jul 6, 2012 10:47 AM
Otahyoni
Indiana Chapter
Oct 9, 2010 05:03 PM
fortynineF6
Jul 24, 2010 05:55 PM
blake 7.3L
Aug 22, 2008 01:14 PM
