What size bolt through smog pump?
Old Sep 10, 2010 | 09:41 PM
izmepeggy's Avatar
izmepeggy
Today while driving , the bolt that goes through the smog pump came out..Thank goodness it was where I could pull over..Now I need to know the size of bolt so I can fix it..It's the bolt that holds it on...Please help.. "88 Ford F-250 , 460 engine
Old Sep 10, 2010 | 10:42 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The 3/8"=16 tpi bolt that the pump pivots on?
You need to know the length?
I'm not sure if they are exactly the same length on a serpentine belt truck as mine.
Old Sep 10, 2010 | 11:11 PM
izmepeggy's Avatar
izmepeggy
Yes..The bolt that holds it on..Under the alternator.. I know that the 460, up until '91 are the same..Thanks..at least now I know what diameter it is..
