Sponsored by: Real Truck
front frame difference
Old Sep 10, 2010 | 12:19 PM
timster24's Avatar
timster24
I have a 2003 F350 and I am looking to stuff a plow on the front for the winter. I have not been able to locate gear in Western or Fisher for my truck but I can find them for late 2004-2007 in Western, however I have noticed some companies sell 1999-2007 such as Boss.
Now my question what is the front frame difference between a 1999-2004 and then the late 2004-2007? or are they basically the same frame?
Old Sep 10, 2010 | 12:22 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I have heard on here that the frames are identical, but I would suspect it has something to do with leaf versus spring and all the mounting points.
If they say it doesn't fit the earlier models, I'd believe them
Old Sep 10, 2010 | 07:51 PM
Fordfanatic4life's Avatar
Fordfanatic4life
each of the different plow makers prolly has attachment brackets that either vary by year or not..
so there is no easy answer as to wether it would work for your truck or not...
Old Sep 10, 2010 | 08:06 PM
timster24's Avatar
timster24
this is what I expected figured there was a small change or something I knew about the leaf to coil spring change but was not sure about everything else. I will just keep hunting for one that fits my year
Old Sep 10, 2010 | 10:51 PM
Rickx's Avatar
Rickx
You may find sme info here:
https://www.fleet.ford.com/truckbbas/index.htm
Look in the Publications Section
Old Sep 11, 2010 | 08:12 PM
Lou Braun's Avatar
Lou Braun
Go to the Fischer web site and use their utility to match a plow to your truck. Basically, many decent plows will fit your truck just fine.
The web site is fisherplows.com or something very close to that.
Lou Braun
SideWinder4.9l
Apr 7, 2013 01:30 PM
rb8484
Mar 15, 2013 11:32 PM
motocamper
Feb 11, 2013 08:51 PM
Loftatsea
Jan 8, 2013 12:18 PM
svein
Dec 11, 2011 11:50 AM
