What should I replace?
Old Sep 10, 2010 | 09:55 AM
amgpro2's Avatar
amgpro2
I am pretty sure I have a massive hi pressure oil leak. It has been slowly getting worse. It is to the point now that the truck will not start until it is completely cold.
My question is, apart from replaceing the sct what other part #'s do you recommend? Dummie plugs stand pipe orings?
Last night I disconnected ICP sensor to force it to default but truck still would not start after a short 12 mile drive. Fuel pressure gauge reads 62-64 psi. FICM was replaced several months ago and batteries crank engine over fast. Specifically I am looking for part #'s to order orings/dummy plugs and stc fitting. I think I have read they have been upgraded unless that was a reference to the stand pipes?
