Startin Issue
Old Sep 9, 2010 | 08:23 PM
thefordlane's Avatar
thefordlane
Startin Issue
I have a 01 ranger. About 3 weeks ago it started starting hard. I would turn the key on(fuel pump does cycle) and crank it and it wouldnt start so i would cycle the key and then it would start. This was everytime i tryed to start it. So i replace the fuel filter and it helped, but it still does it. With the new fuel filter on now it only does it when its cold( starts fine when its warm). Check engin light is on but it did not come on when i first had startin troubles. So im not sure if it is a crank sensor or maybe i need new plugs and wire( still orignal). Any help appreciated.
Thanks,
Old Sep 9, 2010 | 11:45 PM
grandmas77f150's Avatar
grandmas77f150
Have the battery checked
Old Sep 10, 2010 | 12:09 AM
thefordlane
I might, but i just put one in in jan. but maybe its no good.
Old Sep 10, 2010 | 06:01 AM
V8Ranger302's Avatar
V8Ranger302
If its turning over fine, the battery is not your problem. Check the fuel pressure
