Engine Fan Help
Old Sep 9, 2010 | 07:38 PM
jsduty's Avatar
jsduty
Engine Fan Help
Hello all, looking for some advice on what to do concerning a constantly running engine fan. After driving through a sandy mud trail, my radiator possibly took on some sand resulting in the engine fan problem. After researching on this site I decided to try unplugging the fan, but it continues to run and my understanding is that this implies that the unit is bad. I'm considering pulling radiator to try cleaning it and if the fan is bad change it. This will be my first time working on my own 6.0 PSD now that I have 80,000 miles. Can you help please ????
Old Sep 9, 2010 | 07:43 PM
69cj's Avatar
69cj
No matter what the base problem is, if your cooling system took a blast of wet sand, I would clean it. Even if not plugging the fins it could prove to be corrosive. Start from there.
Old Sep 9, 2010 | 08:00 PM
jsduty's Avatar
jsduty
Is pulling the radiator hard and what do I need ?? Thanks I am new at this
Old Sep 9, 2010 | 10:50 PM
4wlflyer's Avatar
4wlflyer
Not to bad drain it take the hoses off take the shroud off the bottom it is a bit of a pain but it will pop out take the two hold downs off the top and it should slide out.
Old Sep 9, 2010 | 11:36 PM
John Irwin's Avatar
John Irwin
If you searched enough you might have found my couple of posts about running a weatherfront in summer (didn't realise they were weather fronts) and how the fan was driving me crazy, took them off, and it isn't hardly noticeable any more. So if the rad or something in the stack is plugged up, it can make the fan come on excessively.
Old Sep 10, 2010 | 05:00 PM
jsduty's Avatar
jsduty
can some one tell me what the two hard lines are on the bottom of radiator please they are the last conections to remove
Old Sep 10, 2010 | 06:42 PM
69cj's Avatar
69cj
Haven't had mine out but they are more than likely tranny cooling lines.
Old Sep 10, 2010 | 07:06 PM
Randy777's Avatar
Randy777
I had the same thing. After pulling a hard grade and high temps my fan kicked in but would not disingage after temps came down. I unplugged it but it still kept running. After an hour and a half it finally quit. This happened a few more times with it taking longer to disingage each time. Had to replace the fan clutch. Check out the parts guy on this site if you have to do the same. He was $220.00 cheaper than my dealer for the fan clutch.
Old Sep 10, 2010 | 07:14 PM
cheezit's Avatar
cheezit
they are trans cooler lines.
heres the right tool to remove the lines with so you know what it looks like
I am not saying to buy it here I have no idea who that company is.
Assenmacher Specialty Tools - 1/2" Oil Cooler Line Remover Tool
Old Sep 10, 2010 | 08:00 PM
jsduty's Avatar
jsduty
That was fun removed my first radiator and cleanend the fins reinstalled and the fan is still on, so it must be the fan cluch. what will I need fore that job and also those hard lines had red fluid is that what is the trany coolant? and how do i top off ?
Old Sep 10, 2010 | 08:12 PM
rocky1074's Avatar
rocky1074
Well one good thing it's made in the good old USA
Old Sep 11, 2010 | 09:28 PM
John Irwin's Avatar
John Irwin
Tranny COOLER. It's transmission fluid. If it needs topping up, make sure to use the right fluid, Mercon SP
Old Sep 12, 2010 | 02:10 PM
jsduty's Avatar
jsduty
Thank you all so far I now at this time removed my fan clutch Yay baby!!! and I have a ????'s is it the pully above the water pump to the left with the smoth side that i need to check for the paint being rubbed off by the belt. THANKS J
Old Sep 12, 2010 | 02:12 PM
cheezit's Avatar
cheezit
yes... you should look at all the flat sided pullies. that would include the water pump pully and the belt tensioner.
Old Sep 12, 2010 | 02:26 PM
jsduty's Avatar
jsduty
THANKS they still look black to me, If the paint was gone are the pully's polished down to bare metal??
