Exhaust Manifolds
Old Sep 9, 2010 | 11:41 AM
catbird7's Avatar
catbird7
Exhaust Manifolds
Does anyone have info on the best replacement exhaust manifolds? I have an 89 F350 with 7.3 IDI and both have cracks & leak. Also, was this an original equipment design flaw or an indication of how the truck was treated by previous owner? What causes cracks???
Old Sep 9, 2010 | 01:18 PM
oreocreaming's Avatar
oreocreaming
ive got a set if your interested. pm me, im in california
Old Sep 9, 2010 | 08:14 PM
Sycostang67's Avatar
Sycostang67
It's not a real common occurence, but it has happened to a few people, me included.
Old Sep 9, 2010 | 08:25 PM
greywynd's Avatar
greywynd
Okay, I gotta ask....... do you find these cracks by visual inspection? Cause unless you're turbo'd, I can't see how one would ever detect it by ear. Heck my muffler has to almost fall off before I realize the thing is leaking!!
Old Sep 9, 2010 | 08:27 PM
Sycostang67
I saw the crack in my manifold and it became even more evident when soot started creeping out of it.
Old Sep 10, 2010 | 06:46 AM
catbird7's Avatar
catbird7
Mine were cracked when I bought the truck and it was obvious when you first start out or bog the engine or if you let it sit and idle. You can hear it, smell it (exhaust fumes in cab), and see it. It's not noticeable at all traveling down the highway. Both sides are cracked and appear as if they would break into three pieces when removed from the engine. I'm the second owner, the first guy pulled a gooseneck livestock trailer up and down the mountains of central PA.
Old Sep 10, 2010 | 07:22 AM
greywynd's Avatar
greywynd
I had a 5.0L F150 that literally did fall into pieces when the manifold was removed, unfortunately on them it was a common occurrence, so there weren't many around to replace. I ended up finding steel ones from a Mustang and had the y pipe reworked to suit.
I'll have to take another look at some of the ones here, I don't think any are cracked though......
Old Sep 13, 2010 | 12:22 AM
Sycostang67
Here is my busted manifold.
Old Sep 13, 2010 | 12:35 AM
oreocreaming
man syco, your not supposed to use tnt for gasket maker on those things haha
Old Sep 13, 2010 | 09:03 PM
Sycostang67
Go big or go home, right.
