Stabilizer Bar
Old Sep 9, 2010 | 02:19 AM
romod's Avatar
romod
Stabilizer Bar
How do I post a picture of my problem? It says at the bottom of the screen "I may not post attachments",,its kinda hard to explain my problem but it looks like my stablizer bar is out of shape or bent where it connects to the bar link,but i'm not sure if its normal or not thats why I wanted to post a pic to see if its alright or not or dangerous.Its a 2000 2.5 2 wheel drive...
Old Sep 9, 2010 | 08:13 AM
grandmas77f150's Avatar
grandmas77f150
Load the pictures to photobucket then post the [IMG] code here
Old Sep 9, 2010 | 01:56 PM
romod's Avatar
romod
Thanks grandmas,I'll try it tonite after I get off work,,,whatever it is broke in two today when i jacked up the vehicle to take off the tire,,if it is indeed the stablizer bar link I looked on autozone website and didn't see any replacement parts..
Old Sep 10, 2010 | 02:51 AM
romod's Avatar
romod
Old Sep 10, 2010 | 02:53 AM
romod's Avatar
romod
That was the front driver side with the wheel off wish-bone suspension type,can I get the part and how do I get the old one off ?
Old Sep 10, 2010 | 10:23 AM
mfp4073's Avatar
mfp4073
Well the sway bar (stabilizer bar) is curved. I dont see damage to it. What I do see is that your end link, the connection between sway bar and lower control arm is broken! Old one off will probably take some sweat, muscle, vice grips and ratchet. Might need to resort to a cut off tool (saw, grinder, etc). new one should be available at parts stores. Called "end link" or "sway bar end link" or "stabilizer bar end link". Fairly cheap.
Welcome aboard! Post up/add your sig/location etc. That will make it easier for us to direct you to the stuff you need (dont want to tell someone in Tasmania to stop into autozone now do I?)
