Weak brakes
Old Feb 20, 2003 | 12:40 PM
wrangler76's Avatar
wrangler76
Weak brakes
Hmmmmm... I have sketchy brakes on my '79 F-350 4x4...
Old Feb 23, 2003 | 10:00 PM
Scot's Avatar
Scot
Weak brakes
Originally posted by mil1ion
Lariat,
To get the maximum effect of braking in Original form,you need to swap in the booster & M/C off an F-350.
The difference is unbelievable.
I keep hearing that but when I did that conversion on my '75 highboy, the brakes just went from awful up to poor. I had a 79 high pinion disc front and a '79 F350 booster/master/pedals. You could forget locking 33" tires. Put a trailer on the back or a load and it got real bad.
I am going to put a jake on the '78. (see below)
Old Feb 23, 2003 | 10:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
Weak brakes
Scott-
Is your differential valve working OK?
Old Feb 23, 2003 | 10:50 PM
79Lariat's Avatar
79Lariat
Weak brakes
I think the article that Mil1ion referred to also said you had to change the calipers or there would also be a mismatch.
Old Feb 24, 2003 | 12:28 AM
Clearcutter's Avatar
Clearcutter
Weak brakes
Yes the article says if the calipers are not replaced with the ones to match the same displacement as the m/c ( 70's car) that the stopping power would actually be worse with the new f350 booster m/c. The article was fairly detailed, there is a few parts that need to be bought also for the brake line adaption, I found some of the parts on the net and others in summit mag. Looks like a cool upgrade that I would like to try also. Let me know what you find out.
Joe
Old Feb 24, 2003 | 05:36 PM
Scot's Avatar
Scot
Weak brakes
Originally posted by Torque1st
Scott-
I used the F350 unit and also a Wildwood adjustable unit which only regulated the rears down enough to keep from locking, like they could. The article shows that the double piston calipers (F250) are almost exactly the same area as the preferred units. I tried Performance Friction pads and ended up using a softer organic pad. Brakes were still marginal. I was flying blind when I did all this 8 years ago or so.
