Hi Guy's, I have a 95 f350 stock. It was running bad so I changed the Ipr, now it wont start. It spinning like crazy but no start. no smoke coming from exhaust pipes no anything. Tack is moving Changed cps first. Oil is fine, so are batriers. Thanks in advance.
Check the fuses, specifically the maxi fuses under the hood. Chances are one is blown. Unplug the fuel bowl heater, replace the fuse and I bet it starts.
Did you change the IPR for a reason other than it was just running bad?
2 years ago I replaced wiring harness, it ran fine until now. When it would crank up, it would run for about 3 sec and cut off. i had to crank it 3 or 4 times to get it running. Thats when I changed the ipr, now it wont start. A 30 amp fuse was blown, i replaced it. Still no start.
Did you unplug the fuel bowl heater? That 30 amp fuse might be blown again...
I unpluged the heater, still no start. Fuse was not blown this time. I think maybe fuel pump or idm. Man I love this truck when its running,but when its down Wow what a pain.
Oh No, the dealer?!?!?! I hope you get someone that knows what he's doing... Wish I could help, but there are others here that will get you fixed if you want..
Thanks guys, I'm going to send the IPR back, they said I may have gotten a bad one.
