Missouri Chapter Join Chapter , Leader:77&79F250
am looking for...
Old Sep 8, 2010 | 06:08 PM
zstangkrewson's Avatar
zstangkrewson
am looking for...
does anyone know of or have an idea on where i can get a bumper like this one has? for a 1990ish model???
or maybe if anyone here knows anything about fiberglass, maybe i could make a shell to cover my bumper with a look-alike of this one???
ty for any help!
Old Sep 8, 2010 | 08:43 PM
pintoches's Avatar
pintoches
My wife said that is one ugly truck.
Old Sep 9, 2010 | 01:25 PM
cyclopsblown34's Avatar
cyclopsblown34
I dunno but I like it.
Old Sep 9, 2010 | 01:52 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Shelby clone
Looks like a "Shelby" clone, see attachment. And I have NO idea where to get a bumper cover/wrap like it has on it.
I do not think you would get enough air flow to the radiator causing cooling issues? But I am pretty sure some where on the internet you can find one.
Old Sep 9, 2010 | 06:03 PM
zstangkrewson
I would never cover up my grill and headlights like that, but i would like to install lights into my bumper which is solid faced. and even have a lower skirt under my bumper.... Now i have a new question:
I think i have a short somewhere in my wiring, i just put new bulbs into my 90 f150 with a 300-6 4.9Ltr motor, because the low beams went out on my, well now my truck sputters going down the road, sucks alot of gas, and even tries to shut off going down the road, i literally have to floor it o get it to move. i put new bulbs in it and this morning it blew the low beam part of my bulb out again... and its really sputtering badly, i feel its a short because when its sputters, some of the dash lightins and warning lights flicker, how do i go about tracing where this short might be? could it be a bad ground wire?
Old Sep 10, 2010 | 09:50 AM
cyclopsblown34
Start it up and do a wiggle test. Start wiggling wires at the headlights with them on and see what happens, work your way through the engine compartment harness, you're bound to find it, also check the wiring block at the firewall to make certain it has a good connection.
Old Sep 11, 2010 | 09:19 AM
zstangkrewson
found out i had a loose wire at teh fuel pump relay, got it to stop cutting out so far, but wierd thing about he headlight bulbs, it exploded the bulb, the last one too... att $12 a pc its getting pricey to replace... for some reason its like its getting way too hot or too much juice and making it pop?????
I need to ge taround to my explorer asap and see exactly where the tranny fluid is pouring out of, im hoping its a converter or a front seal so i can replace it and hopefully be back on hte road with it before winter... anyone here drop a trany out of an explorer 91 model???? is it hard?
