Greasy hub!
Old Sep 8, 2010 | 04:36 PM
procraft's Avatar
procraft
4th Gear
Greasy hub!
I have a squeaky brake. I took one of the rear tires off to check the brake and found a very greasy everything. A nice smelly thick coat covered everything. Is this an axel seal problem? Is it something I can do myself? Oh yeah, 2004, XLT, ext. cab, 4.0, 4x4, 4.10 limited slip. The good news is, that brake is not the one squeaking!!!!
Old Sep 8, 2010 | 08:59 PM
bankshot's Avatar
bankshot
The oil seal is leaking. The oil makes the brake squeak. You'll need new brakes also.
YouTube - Ford Ranger axle seals and bearings
Old Sep 9, 2010 | 05:58 AM
procraft's Avatar
procraft
4th Gear
Thanks for the clip!
Old Sep 9, 2010 | 06:31 AM
powersmoked's Avatar
powersmoked
I have heard of a gasket sela but I cant think of what it is called. it is used to repair the sela without pulling the axles. some people say they work and others say they wear out. I know companyies with big equipment use them.
