i have a ford f-150 truck and im trying to change the cassette deck in it to a newer cd player but all the wire color codes for the truck are wrong can anyone help me?
Hi Lester .this chart is not Guranteed to be accurate because they sometimes vary from year to year so it is always best to have a test light or ohm meter to be sure,you can use a portable radio to check the speakers.hope this helps'
FORD
P o w e r
Memory (+12v Constant) Green Yellow
Ignition (+12v Switched) Yellow/Black
Ground (-) Black or Fat Red
Illumination Orange
Dimmer Orange/White
Power Antenna Blue (varies greatly)
S p e a k e r s
Right Front (+) White/Green
Right Front (-) Green/Orange
Left Front (+) Orange/Green
Left Front (-) Light Blue
to check for speakers, grab a 9V battery. When you connect the right two wires with the 9V, the speaker will make a 'pop' sound. find all of the speakers, then you should have a 12V constant, 12V switched, and maybe a few more..pending on options.
