hazard light issue....?
Old 09-07-2010, 08:52 PM
SparkyRnD's Avatar
SparkyRnD
SparkyRnD is offline
Recently bought what I've been told is a 1976 F100, but appears to have some 1978/79 items. I have a weird issue: the turn signals in the rear work fine, as do the parking lights and brake lights. All bulbs look good, nothing blown. When I turn on the hazard lights, only the rear passenger light activates. Everything else is dead. What in the world would cause that?
Old 09-07-2010, 11:05 PM
TexasTrash's Avatar
TexasTrash
TexasTrash is offline
There are two of these under the dash above the fuse box, one is for the turn signals and the other the flasher. I would change that, its most likley it.
Old 09-07-2010, 11:07 PM
TexasTrash's Avatar
TexasTrash
You could actually swap them and see if your flashers work, then you would know if it is it or not.
Old 09-08-2010, 08:11 AM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Do you mean the rear passenger light actually blinks or just turns on?
Old 09-08-2010, 09:06 AM
SparkyRnD's Avatar
SparkyRnD
first thing I did was check the bulbs, they are all good. Next thing was to replace both flashers. When I turn on the left turn signal, the left light blinks correctly. When I turn on the right turn signal, the right light blinks correctly. When I apply the brakes, the brake lights come on correctly. When I turn on the parking lights, the rear parking lamps work properly. When I turn on the hazards, the only light that comes on / does anything is the passenger rear, and it flashes. No other light on the truck comes on or flashes when the hazards are on.
Old 09-08-2010, 12:16 PM
berry1234's Avatar
berry1234
berry1234 is offline
Pull the flashers, check for corrosion. Swap with other one, see if it works.
Old 09-08-2010, 12:37 PM
SparkyRnD's Avatar
SparkyRnD
already did, wasn't the issue (even tried it again with the new flashers)
Old 09-08-2010, 12:44 PM
berry1234's Avatar
berry1234
Did you check the corrosion on all bulbs in question? I would invest in a bottle of contact cleaner DeOxit is a good one.
Old 09-08-2010, 12:56 PM
SparkyRnD's Avatar
SparkyRnD
yep, checked that, checked the grounds, etc. They all work except when I put on the flashers. I wonder if the flasher switch is going bad, or if the column wiring is messed up (getting the impression that this truck is a hodge-podge of years)
Old 09-08-2010, 12:58 PM
berry1234's Avatar
berry1234
Can you get access to the flasher switch? Spray cleaner in those contacts and work the switch a bunch of times. Wiggle it a bit. See if the don't come on.
Old 09-08-2010, 03:17 PM
tinaheels's Avatar
tinaheels
tinaheels is offline
sounds like the turn signal switch is screwed up
SeaCarr
08-29-2021 09:14 PM
snavemit
02-04-2016 08:16 PM
miihere24
44
01-14-2016 12:32 PM
stownsen914
1999 to 2016 Super Duty
04-23-2014 08:44 AM
mythbustingpyro
06-19-2013 05:45 PM
Quick Reply: hazard light issue....?
