Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Noise when going uphill
Old Sep 7, 2010 | 01:11 PM
ferrer's Avatar
ferrer
Hi,
I have a Ford Escape 2008, V6, FWD, 26,000 miles. Sometimes when I'm going uphill at low speeds I can hear a noise that sounds like marbles in a can. This is an occasional occurrence, does not happen every time I drive. No indicator warning lights. If I change to neutral or remove my foot from the accelerator, the noise stops.
I did a search on the web and found that this could be "Engine knock" and one of the recommendations is to use a higher grade fuel. Currently I use Shell 87 (as indicated in the User Manual). Should I try 89 or 91? Is it recommended for the Escape 2008?
Do you think this could be a different problem?
Thanks in advance for your comments and suggestions.
amyr61
Oct 3, 2015 05:45 PM
baronep
Aug 6, 2015 08:49 PM
cchighman
Sep 11, 2014 09:15 PM
Partime
Jun 28, 2013 05:25 PM
seattlem45
Jun 4, 2010 08:13 AM
