Saw on Ebay a camper special that appeared to have factory under hood insulation. I know u can buy aftermarket type (dynomat etc.) cut to fit custom install but does anyone know if oem is availible or part number?
1st one i have ever seen or remembered? Sure looked factory just wondered why they sold the plastic push pins and hoods have the holes there? hopin this is for real.
Ebay item 310246021324, Brown 1979 ford f350 with slide in camper just watched the video clip of it you can clearly see the liner and seller makes note of it being rare. Still photos had a picture with hood up sure looked factory molded. Any nos lying around part number, help?
My 1979 f150 Ranger XLT 4x4 has a hood liner in it. I really never noticed it or thought much about it, I think it is oem it is really old and gray looking with a few tears in the wool/insulation. Fits tight and clean with some type of a plastic pin to hold it in place. Are these factory or what, would like to know? Checked for some in the U-pull yard today, saw a partial one in a 1979 Bronco. Only the 1979's had the holes in the hood for the push pins, interesting. Does Number Dummy know?
That liner does look factory. And like others said, why would there be holes in the hood brace for a clip of some sort. Bill might be able to chime in here.
