Trans Not Going Into Overdrive
Old Feb 18, 2003 | 06:27 PM
icebreaker88's Avatar
icebreaker88
I HAVE A 95 PSD, E4OD AFTER I BOUGHT IT I NOTICED THE BUTTON ON THE SHIFTER WAS NOT WORKING ALL THE TIME. I HAD TO HIT IT A COUPLE OF TIMES BEFORE THE LIGHT CAME ON. NOW WHILE I WAS DRIVEING IT WOULD NOT GO INTO OVERDRIVE AND THE BUTTON DOES NOT WORK AT ALL.
Old Feb 19, 2003 | 11:29 AM
PSDJB's Avatar
PSDJB
I had the exact same problem on my 2000 PSD that i just bought. I took it to my shop and after running the diagnostics on it and determining that there was nothing wrong with the tranny, they pulled apart the steering console and found that the OD wire had been gradually getting pulled too tight and eventually became disconnected. Something to that affect...cost me an hour and a half of labor.
Don't know if this is what's going on with yours, but it sounds similar.
Old Feb 20, 2003 | 04:37 PM
icebreaker88
well it turned out to be the sme thing the wire to the switch in the steering colum broke or got pulled apart.
so it costed me 2 hours of labor. @$80 a hour
but better than new trans
and found out the trans was replaced once before.
Old Feb 21, 2003 | 08:16 PM
PSDJB's Avatar
PSDJB
Glad it worked out for you.
My 250 had its tranny replaced too. I guess it went out on the previous owner at 29,000 miles...yikes. It's got 43k now...so far, so good.
