05 cruse control issue?
Old Sep 6, 2010 | 09:25 AM
Big Dirt's Avatar
Big Dirt
If I use the coast control under 35mph, the engine dies. This can't be normal. Is there a flash available to update this problem or is it mechanical? Thanks.
Old Sep 8, 2010 | 02:52 PM
zecolleman's Avatar
zecolleman
Could be the sensor in the main brake pump where you put your brake fluid . It have happent to my but that was when this sensor was broken and abs light was coming on now and then.I replace this sensor and It have not stal since but I have just test it ones on so low speed since..
