Turn signal problem
Old Sep 5, 2010 | 05:29 PM
cabloom300's Avatar
cabloom300
Turn signal problem
As i was driving today all the sudden my right turn signal wasent working in my 96 F150. The left turn signal is fine and you can here it click. The 4 way flashers work on both lights and the headlights work on both as well. I forgot to mention this is just in the rear. When i turn it on theres no clicking and the light on the dash is a solid green. Any help would be great. Thanks
Old Sep 5, 2010 | 05:42 PM
96ford250's Avatar
96ford250
theres a fault some where each tail light has their own power line so it has to be that line or a ground
Old Sep 5, 2010 | 08:13 PM
cabloom300's Avatar
cabloom300
Anywhere specific along the line? i would think it wouldnt be a ground since it works with the headlights on. Also the light doesnt work when the brake is applied either
Old Sep 5, 2010 | 10:16 PM
96ford250's Avatar
96ford250
hmm can you give me a real in depth decription cuz im getting confused here when does it work and when doesnt it
Old Sep 5, 2010 | 11:52 PM
LCAM-01XA's Avatar
LCAM-01XA
Turn signal switch going bad? Actually are you saying that when the headlights are on the turn signal blinks like it should, but with the headlights off the blinker goes dead and so does the brake light on that side?
dmarsh2400
Aug 19, 2019 03:23 PM
Troglodyte
1983 - 2012 Ranger & B-Series
Feb 10, 2012 09:23 AM
anteru
Jul 21, 2010 04:53 AM
micklskot
16
Apr 4, 2009 01:10 PM
