Dash Pad Removal
Old Sep 5, 2010 | 04:44 PM
macgiobuin's Avatar
macgiobuin
Dash Pad Removal
The dash pad on my '66 finally got to the point of no return. I was cleaning it, and every time a put a little pressure on it, new cracks would form. So, I bit the bullet and removed it. Turned out to be a LOT easier than I thought it was going to be. The paint underneath was also much nicer, and looks a ton better that the old, cracked dash. I do have a tip for anyone removing their dash pad: try "Sticker Shock" bumper sticker remover to get the old glue off the top of your painted dash. I used it, and it did a GREAT job...the glue turned into a rubbery texture, and then just rolled up and off when I wiped the dash with a cloth. Just sprayed iton, let it set a couple minutes and wiped. Most of the old glue came right off. I did have to use a plasctic scraper in a couple spots, but the whole process from unscrewing the first vent screw to putting the cap back on the container after waxing the newly revealed dash took me right at 3 1/2 hours. That was while talking on the phone, and doing a couple "Can you carry this for me?" jobs for the wife during the process.
Old Sep 5, 2010 | 05:27 PM
66crawler's Avatar
66crawler
Sounds good, wd40 works pretty good on some sticky stuff, goof off works good to. Glad yours came out good.
Old Sep 6, 2010 | 07:52 AM
macgiobuin's Avatar
macgiobuin
Thanks. I hadn't even thought of WD-40...I'll have to remember that as well.
Old Sep 6, 2010 | 10:25 AM
SixtySix Ford's Avatar
SixtySix Ford
where can you find that sticker shock at?
Old Sep 6, 2010 | 11:13 AM
macgiobuin's Avatar
macgiobuin
I got it at one of the chain autocare stores....I believe it was AutoZone, but could have been Oreillys or Pep Boys. I bought it about 2 years ago to remove an old bumper sticker the previous owner had placed on my truck and had worn out.
Old Sep 6, 2010 | 11:23 AM
SixtySix Ford
OK cool! I will have to check thems out and see what I can find! I did the same thing you just did a couple weeks ago and that glue #@$%@ is driving me up a wall!!!!!
Old Sep 6, 2010 | 05:03 PM
kylejhowe's Avatar
kylejhowe
my dash pads pretty whipped but i dont want to not have it. do you know where i can get a new one or something like that? i know lmc truck but if i remember it was 600 or 700 buck. or something crazy
Old Sep 7, 2010 | 12:17 PM
macgiobuin's Avatar
macgiobuin
Frank at Just Dashes says a black reproduction padded dash for 61-66 full size Ford pickups will run you $400 plus shipping right now.
Welcome To Just Dashes
D.R.66f100
Nov 28, 2013 05:37 PM
f-150_1993
Jun 27, 2011 04:32 PM
Gary Lewis
Mar 6, 2011 09:42 AM
snakedoc
Apr 8, 2010 09:21 PM
Big Red
23
Jul 18, 2005 06:38 PM
