what heads for SBF?
Old Sep 5, 2010 | 04:31 PM
Saber123316's Avatar
Saber123316
what heads for SBF?
so i have the chance to get a set of fully ported and polished heads for a SBF 2.06 int and 1.6 exh there edelbrock performer heads.
any idea if I should or shouldnt for my truck?
trucks a 351 4x4 that im turning into a street / strip truck.
Old Sep 5, 2010 | 05:33 PM
lew52's Avatar
lew52
The edelbrock heads are good , there are some that flow better , but a very good upgrade , i thought there SBF heads were 2.02 on the intake ??
Old Sep 5, 2010 | 08:08 PM
Saber123316
actually I may have a set of dart iron heads that are 550 bucks and flow the same amount of air at .500 lift
Old Sep 5, 2010 | 08:16 PM
fordyduty's Avatar
fordyduty
If it's a good deal for them then go for it. I would check the heads out of course first, check for any head warpage, check valve guide play, and take a peak at some of the valves and seats if possible. Having a set of heads redone can cost a lot. For example say you pick up both heads for 500. and they need to be hot tanked, magnafluxed, plained, valve guides redone and both valves and seat be ground, depending on the machine shop you could be dropping another 500+ before you bolt them on.
Don't get me wrong here they are good heads just saying sometimes used heads can be a huge PITA so check them out real good first thats all.
