Srorage question?
Old Sep 5, 2010 | 03:53 PM
Knightruler's Avatar
Knightruler
Srorage question?
I recently purchased an older (1981) Scamper motor home with a ford 460 engine and Auto trans. I then replaced all the gaskets and seals(almost). The valve cover gaskets the oil pan and rear seal.
I am assuming I had to replace all this because this vehicle was stored for long periods(several years). And they dried up.
I don't want to have replace these things again so I plan to start it up every once in awhile. It's going into storage for the winter in a couple of weeks.
My question is what time frame should I start it up and let her run. I was thinking about once a month. What do you think?
Old Sep 5, 2010 | 07:24 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Once a month is what I would recommend.
Take it for a drive as well. This will get the motor, rear end, tranny lubricants, if applicable, moving as well, so there wont be any rust spots or dried out seals forming on the other drive train components.
Old Sep 5, 2010 | 07:48 PM
ctubutis's Avatar
ctubutis
As well as the clutch & brakes; when I repalced the clutch on my 1981 F350 it was obvious it
had gotten wet and then sat for a LONG time, the flywheel was corroded & pitted where the
clutch material had trapped water against it.
Old Sep 5, 2010 | 08:18 PM
Knightruler
81-F-150-Explorer:
Can't take it for a drive the insurance expires next month. Good idea tho...
ctubutis:
Mines an automatic so I catch a break there. I won't ask about your avatar......
Old Sep 6, 2010 | 10:54 PM
ctubutis's Avatar
ctubutis
https://www.ford-trucks.com/forums/9...ml#post9230032
Old Sep 7, 2010 | 11:12 AM
Knightruler
Thanx for the link. I figured it had to be something like that. Actually I thought you were the one that was drunk. Or had lost a bet.
Funny picture in any event, and NO, it didn't bother me at all.
Thanx for sharing....
