Anyone seen this behavior?
Anyone else seen this type of behavior?
Thanks.
Bryan
Memory seat/power mirrors/adjustable pedals (Two-button switch) (if equipped)
This system allows automatic positioning of the driver seat, outside rearview mirrors and adjustable pedals to two programmable positions.
The memory seat control is located on the driver’s seat.
• To program position one, move the driver seat, exterior mirrors and adjustable pedals to the desired positions using the associated controls. Press and hold control button 1 for at least two seconds.
• To program position two, repeat the previous procedure using control button 2.
A position can only be recalled when the transmission gearshift is in Park (automatic transmission). A memory seat position may be programmed at any time.
Activating the three-button memory switch (if equipped)
To activate this feature:
1. Position the seat, power mirrors, adjustable pedals and steering
column (if equipped) to the desired positions.
2. Press the SET control on the
driver’s seat memory switch.
3. Within five seconds, press the 1
or 2 control on the driver’s seat
memory switch to associate with
Driver 1 or Driver 2 positions.
4. Press the SET control again.
5. Within 5 seconds, press the
or button on the associated
remote entry transmitter.
6. Press the 1 or 2 control on the driver’s seat memory switch.
7. Repeat this procedure for another remote transmitter if desired.
Deactivating the three-button memory switch (if equipped)
To deactivate this feature:
1. Press the SET control on the driver’s seat memory switch.
2. Within five seconds, press any control on the remote transmitter
which you would like to deactivate and then press the SET control on
3. Repeat this procedure for another remote transmitter if desired.
