checking coil 03 excurion
Old Sep 4, 2010 | 04:03 PM
562deluna's Avatar
562deluna
i have an 2003 excursion,i had engine light on and had it checked they told me it was a bad coil but did not indacate witch one-- how can i check coils Thanks
Old Sep 4, 2010 | 04:53 PM
Rongold's Avatar
Rongold
Checking Coils
Whoever scanned it for you should have told you which coil it is. When you scan the PCM, and you have a miss, you will come up usually with a code P0300 thru P0310---300 being random misfire (more than 1 cylinder misfiring) or some code between 300 & 310. The number after the 3 tells you which cylinder it is. Example---P0302---cylinder 2. P0309---cylinder 9. If you paid for the scan, go back and insist that they tell you which cylinder it was. If it was done as a favor, ask the same thing nicely.
Just because there is a misfire, it is not necessarily a bad coil. It could also be a clogged or bad injector or a bad coil boot. You could measure the coil resistances also, and compare them to each other, but that won't tell you if one of them happens to be cracked. Also, it's a PITA getting the last 2 coils on each side out---They're under the windshield, and you have to be a contorsionist to get back there.
Let us know how you make out.
RON
Old Sep 4, 2010 | 05:33 PM
562deluna's Avatar
562deluna
it was done free at aamco so they wont tell witch one only what is
steeltown08
Mar 27, 2017 06:08 PM
Jmschneider
Jul 21, 2015 08:51 AM
Fordenthusiasts
16
Jun 21, 2012 06:23 PM
tjs_79ford
Sep 20, 2009 11:30 AM
Superdave
Jun 12, 2009 11:13 AM
