I'm thinking closer to 300lbs. I figure almost a 100lb for each hub/drum and andother 100 for the pumpkin. All I know is, it is heavy! I had it completely off my 69 for leaf spring bushing replacement.
I purchased one from the local pick and pull for $100 including drums and springs. Three of us could not lift it. Three of us could not drag it out from under the truck we had to get a fork lift. You are going to spend a whole lot more than $100 on shipping.
Its been a while, but the last time i moved it, i loaded into my rig myself and nearly blew a gasket. I was figuring somewhere between 300-400lbs. It can be done, just lift one end put it on the tailgate, and go lift the other end. Youll need to take right ahold of it, its kinda heavy.
You know, strong back and weak mind.
