I have 81 f-250 4x4 sc that i swapped a modded "88" 300/t-19 to replace the 351m/c6.
I keep the HD radiator from the 351 but the stroud dint fit.
The doner truck(80 f-150) for the swap only had a small shroud at the top and i have never seen a shroud on the 300s in these models.
Did the f-250/350 with the 300 have a full shroud?
thanks ron
I don't know the answer to your question, but I'd try to find a shroud that fits as it plays a big part in keeping your engine cool. If you do end up making/modding a shroud to fit, make sure that the rear face of the fan is poking out about 1/2" or so out of the rear of the shroud.
