Need some advice
Need some advice
Hi I bought the window upper visors fit not great if I remove or can loosen the trailer tow mirror I can slip the visors under then the look will be better any one know how they come apart or just loose for this job I don't want to break some thing so though I would ask..My e-mail is johnmc@ yaho.com and thank You
I believe you would like to fit the Rain shield visor that goes on the door under neath the tow mirror molding.
With the door open pop out the black triangular plastic piece, it snaps in and out. There are some bolts, loosen them some then the outside molding can be pulled away some to fit the visor behind. I don't think you have to take the inside door panel off, it's been years since I put the visor on the '05'.
When I put my visors on, I loosened the mirror and put the tip of the visor under it, and tightened up the mirror. Here is a link that might help you, if you haven't figured it out yet.
http://www.dfuser.com/Install%20Guid...stallation.pdf
codymoch
06-06-2007 09:17 AM
