Need Help, High Idle Problem
Old Sep 3, 2010 | 11:50 AM
Auztone's Avatar
Auztone
Hey guys need some help in trying to figure out a High Idle problem I have on my 1995 E150 5.7L Econoline Van. It starts up just fine and actually idles okay initially. I’ll put it in gear and drive off, after it warms up just a bit I’ll come to a stop and the van will be idling high. I have to stand on the break to keep it stopped.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o> </o>
After searching in this forum I took some measurements (I also have an Engine Light on) and found what I believe was a bad TPS. In all I replace the IAC and the TPS and the problem hasn’t gone away. I get a fault code of PO0122 which is the TPS even after replacing it? So my question is it possible I got a bad TPS or something else could be causing the issue? Any help is much appreciated.<o></o>
Thanks
Old Sep 5, 2010 | 10:51 PM
cmbro's Avatar
cmbro
I had the same problem and it turned out to be the wrong voltage at the TPS because the throttle body stop had been messed with.
Old Dec 4, 2010 | 08:09 PM
Econo150's Avatar
Econo150
Having high idle issues also
Hi everyone, I have an 86 Econoline 150 (EFI) Is there an adjustment to lower the idle or is there something else that can be adjusted to lower it ?
Old Jan 9, 2011 | 09:40 PM
cgifly2's Avatar
cgifly2
Its a tps problem still. Either incorrectly installed or ther wrong one.
Kart18
437
Mar 14, 2018 05:20 PM
myakkacracka
13
Jun 16, 2016 11:33 AM
dk4182
May 19, 2016 10:30 PM
ford-runner
Nov 4, 2011 03:11 PM
5Rangers
Jul 25, 2011 09:42 PM
