Sponsored by: Auxito
gear ratios
Old Sep 1, 2010 | 06:44 AM
dtaylorlc's Avatar
dtaylorlc
gear ratios
I have a 2002 F-150 2wd with the 4.2 v6. I just put new tires on and moved up a size to 265/75-16. I love the tires and the look but my rear gears are going to have to go. I currently have 3:31 and going 75mph I run about 2000 rpm, no bottom end. I'm looking to see if anyone has anything similar or any advice.
Thanks
David
Old Sep 1, 2010 | 07:45 AM
Johnny Langton's Avatar
Johnny Langton
Thanks
David
With a 4.2L,you need a 4.10 or more, IMO. That engine doesn't make enough torque down low to keep the vehicle moving at speed, and the extra torque multiplication will make driving altogether a much better experience. You'll likely see no loss or possibly even a gain in fuel economy as well since the engine will not see as much load.
JL
Old Sep 1, 2010 | 01:24 PM
dtaylorlc's Avatar
dtaylorlc
I have been considering 4:10's but I don't want to run too many rpm going down the highway. This is my primary vehicle so I don't want to go to much on the rear end, I'm not sure how the 4:10's will do when traveling.
david
Old Sep 1, 2010 | 01:30 PM
Johnny Langton
david
You're gonna turn approx 800 more rpm's than with the stock gearset. You'll honestly see little or no loss of MPG because the engine will be under less load and will consume less fuel .
JL
Old Sep 1, 2010 | 04:15 PM
redwood's Avatar
redwood
I agree with Johnny on this one. If you really, really feel like a 4.10 is too much, I wouldn't go any further south than a 3.73.......
Here's a gear ratio to tire size chart. It puts you right where you need to be with a 4.10:
Differential Gear Ratio Chart - Tire Size to Gear Ratio
Here's a tire size conversion chart from metric size to inches:
Tire Size Calculating Form
Old Sep 1, 2010 | 05:01 PM
dtaylorlc's Avatar
dtaylorlc
Thanks for the info it looks like with the overdrive the 4:10s are the way to go.
Thanks
