I have a late 1995 F-250 7.3 PSD, about 9 months ago it started to get longer and longer to start then one day it wouldn't start at all. Then when it got cold again i started it and it started right up. so i came to the conclusion when it is cold it will start, also i can roll start it pull start it w.e... my buddy said when i am cranking on it the injectors are not clicking it sounds like. so anyways i put these following into it.
CSPS
IDM
PCM
Cleaned the EBPS tube
now i do not know what else to do please help me
if i need more info ask i am sure i have more in me...
I went through 3 IDM's before I got mine running, ran like crap, found out it was the injectors. Check the wiring to the injectors, see if the condition of the valve cover gasket is in good shape, wires and all
Y i ask is. Heat will raise the resistance of electrical parts. If you have some bad connections somewhere. It would cause the resistance to be up and the heat just makes it worse to the point it wont pass enough current.
