NY's September B/S and Chat Thread... everyone is welcome
#109
#111
Good morning and thanks for opening up Steve, Scott, Ken, Pat, George, Carl, Ed, Missy, Art, Brad and all that drop by.
Had an enjoyable weekend and now it is back to the grind.
#114
I have enough days left where I'm scheduling almost every other Monday off in October, November and December, including taking off from 12/23-1/3.......
#115
Good morning to all. Coffee's gone, time to get to work. In going over the 87 I bought, I'm surprised at what parts I've got in stock for it.
#119
Evening all. Neil, I'm just doing a real close general check over (some would say ****). Noticed the rear u joint a little weak - turns out I've got the makings to rebuild the whole drive shaft. Rear tank sending unit no working either pull the bed or drop the tank, can't drop the tank because prev owner had a hitch welded to the frame, bumper supports, spring shackle mount and hitch extended to the cross member in front of the tank. PITA but I'm dropping that hitch and will mount a class IV. Synthetic differentian oil, and trans fluid next on the list. Then a nap..
#120
I can understand where you are coming from with the truck. I have been known to be a little '****' when it comes to going through a new to me vehicle. Sounds like you have your work cut out for you with the trailer hitch.
