63 F250/disc brake conversion
Old Oct 6, 2010 | 06:03 AM
  #31
Hwy51's Avatar
Hwy51
Hi BillW, I LIKE IT!!! Nice work!!
I'm just finding this thread, so just to be sure of what you've done...
You have had caliper mount brackets FABed from 3/8 cold plate to allow for a disc brake caliper and rotor. I think you stated that the rotor is a late 80s GM.
Half ton truck? or 3/4 ton truck?
Are the calipers from the same year/model?
Can you tell me what wheel bearing part numbers it took to make the spindle compatible with the GM rotor?
I very much interested in do this to my 64 F250.
What lessons learned can you pass on to me?
Thanks and nice job again!!
-Hwy51
Old Oct 6, 2010 | 08:48 AM
  #32
Bill W's Avatar
Bill W
Hwy51, thanks, i used 1/4 inch cold rolled steel, rotor form a mid 70's chevy 3/4 ton 4x4 with a caliper and brake hose frome the same, i had the original hub for the drum brakes machined to fit inside the chev rotor. sounds easy but really it was not.
Old Oct 6, 2010 | 11:39 PM
  #33
Hwy51's Avatar
Hwy51
Thanks Bill,
I think I gottcha!!
I'm gonna take my 64 down and start measuring the spindles and looking for rotors that use the same bearings. Once I find that, making the brake calipers fit, will be the 2nd requirement.
-Hwy51
Old Dec 11, 2010 | 08:36 PM
  #34
Bill W's Avatar
Bill W
well folks... it's all finished and back on the road. i had to find aftermarket rims and with that i bought new 235/85/16 tires. i had the drag link bent, cut and welded with a tie rod end so it is adjustable. i have 30-40 miles on it last weekend and today, it stops nice and straight! so far, i am happy with the way it turned out.
anyone wanting a pattern of the bracket, send me a PM
Old Nov 26, 2011 | 02:45 PM
  #35
rolandska's Avatar
rolandska
Curious
How has this worked out in the long run? I picked up a 64 F250 over the summer and this looks like a good winter upgrade.
Old Nov 26, 2011 | 06:02 PM
  #36
bunchoftrucks's Avatar
bunchoftrucks
With bending,cutting and adding a tie rod end did it eliminate any bump steer? I put 2" adda-leafs in my 64 F-250 4x to offset the weight of the snow plow I run in the winter, and haven't been able to find a solution to the bumpsteer.
Old Nov 27, 2011 | 01:09 AM
  #37
garbz2's Avatar
garbz2
What size tires are you running?
What are the condition of the leaf spring bushings?
What is the condition of your stock drag link?
What is the condition of the Gemmer Steering box?
There is a plethora of issues that can exacerbate the bump steer.
Adding lift changes the angle of the draglink and it needs to be corrected to level at ride height, this is inclusive for lifting or dropping the truck.
Garbz
Old Nov 27, 2011 | 11:26 AM
  #38
Bill W's Avatar
Bill W
could not tell you for sure....the truck has about 75 miles since putting the brakes on and now i'm doing more work to it. paint, interior, exaust..etc, etc.
Old Nov 27, 2011 | 01:15 PM
  #39
rolandska's Avatar
rolandska
Feel like sharing the info on the parts you used? and the bracket info.
Thanks Henry
Old Nov 27, 2011 | 07:50 PM
  #40
bunchoftrucks
Garbz2,
tires 255/85/16
leaf springs and bushing replaced less than 1000 miles ago
stock drag link ,tight no slop.
steering box, not the greatest but not like sailing a boat in choppy water either.
The lift is definately the root of the bump steer as my experience has been with lifted trucks. Thats why I was picking billw's brain on his mod's. In the 70's when we were lifting trucks blocks were available but they had draw backs as well and I can't seem to find one. The "right" way as far as I know is to return the drag link as close as possible to parrallel to the ground. Any suggestions?
Old Nov 27, 2011 | 09:33 PM
  #41
garbz2's Avatar
garbz2
Garbz2,
tires 255/85/16
Did you replace the bushing in the frame mount?
You will need to dogleg and extend the drag link to parallel it as you mention. Re center the steering and adjust it to fit.
Did you do any rebuilding on the Dana44 the lower and upper trunnions tend to wear and cause wonder steering also when the spindle goes in and out of camber.
What shocks are you running in the front? Shock selection makes a huge difference in the bump as better shocks provide better dampening of the leafs action that is the main cause of the bump steer.
I have also found that a good single or pair of steering stabilizer shocks from the axle to the tie rod really dampens the tendency to jitter.
Garbz
Old Nov 27, 2011 | 10:22 PM
  #42
bunchoftrucks
Yes I did reolace the frame bushings, I went to a local shop that we have used for heavy trucks as they do everything from cars to semi's. They were able to get me the exact same greasable bushings and that what I used when I replaced the springs and installed the adda leafs. I agree the the drag link is the issue and putting a dog leg into it would be a solution, I liked billw's addition of the tie rod adjuster for fine tuning as well. Finding someone willing to cut and bend a steering component may be the challenge since most shops are liability shy. Yes I have replaced both upper and lowers when I did the knuckle seals and the alignment is good. The shocks are Monroes and in good shape. Yes a steering stabilizer is going to be an addition soon.
Old Sep 27, 2013 | 04:59 PM
  #43
Sooner012676's Avatar
Sooner012676
Originally Posted by Bill W
Yes, i had the hubs machined to fit inside the rotor and i'm using the same spindle
I guess i should have just changed it over to 5 lug half ton, the cost is way more than i thought..... but i can't stop now.
Bill W
I love you have done, I have been looking all over the internet trying to find an F250 brake conversion. Do you still have your templet for the brackets? If so how much do you want for a copy. I am moving to Germany in 6 months and want to get the restoration of my Great Grandpa's 1963 f250 finished before I leave. Any help you can give would be great.
Old Sep 28, 2013 | 01:14 AM
  #44
Bill W's Avatar
Bill W
Wink
Originally Posted by Sooner012676
Bill W
Yeah, i can help! click on my user name, go to "View Public Profile" and leave me a visitor message with you contact info. And... Welcome to FTE.
Old Feb 29, 2016 | 09:12 PM
  #45
PJSsprint's Avatar
PJSsprint
Hi Bill, I am making my own disc brake setup from your pics and thread. Can you send me a pic of your hub alone after you machined it. How is your setup working after a few years? Thanks Patrick
