Reversed battery cable at night
Having trouble with a dead battery on the side of the road a week ago, replaced with our new battery but got the cable on backwards. did not notice at first as headlights, dashlights all come on got it home with a tow strap and friends. To no avail would not crank, that prob turned out to be the clutch switch, replaced then would turn over but no fire. Started checking with a meter for ignition probs found the reversed cables. Still turns over but won't start. what could I have burned out fuse links, relays, eec, etc.
That's ware I would start and if your still having troubles try looking and searching old post. like I said it been talked about a lot the last couple months.
Good luck!
