miss
Old Aug 31, 2010 | 12:52 PM
hartless's Avatar
hartless
miss
hi,
i have a 99 expedition with 5.4,110,000 mi.
i just changed the thermostat in it now it has a rought idle and a miss and the check engine light came on ,and idea why this would happen ? used oem equipment ????
thanks
Jason
Old Aug 31, 2010 | 01:07 PM
bumparker's Avatar
bumparker
Probable cause: coolant ran into one or more of the plugwells when you were changing the ts. Coolant is now causing shorts to occur. Blow out the plugwells and allow everything to dry.
Old Aug 31, 2010 | 02:31 PM
hartless's Avatar
hartless
thanks i will try right now...didnt think of that
Old Aug 31, 2010 | 03:31 PM
hartless's Avatar
hartless
tried blowing everthing out still missing
Old Aug 31, 2010 | 03:56 PM
alloro's Avatar
alloro
Originally Posted by hartless
tried blowing everything out still missing
Antifreeze doesn't really dry very well. I suggest first flushing out the plug wells with water to clean out the AF, then blow out the water. Once you run the engine for a bit the heat will dry up the water in no time flat.
If that doesn't solve it, you're going to have to start replacing the rubber boots on the COPs.
Old Aug 31, 2010 | 05:19 PM
hartless's Avatar
hartless
thanks ...hard to believe something so simple can make such a issue ,will let you know if it dries out in a day or so ,i already washed off the entire engine ..we'll see
Old Sep 1, 2010 | 11:33 AM
pdqford's Avatar
pdqford
and the check engine light came on ,.....Jason
Get the DTC read and post the code here and these guys will get you focused on the problem.......
