1978 - 1996 Big Bronco
looking for some advice
Old Aug 30, 2010 | 09:12 PM
90f150windsor4x4's Avatar
90f150windsor4x4
i just got a 94 bronco with 5.8 and e40d the problems im havin is after you drive it some it loses some coolant but cant find any leaks and doesnt leak when just sittin not goin into oil and the front drive shaft doesnt spin freely when in 2wd it does have auto hubs im not familar with them but my 90 with same drivetrain does spin freely in 2wd with manual hubs and when you lock them in it does the same thing as the bronco is doing turns just a little and stops im thinking the auto hubs are stuck engaged but not sure how to fix or diagnose and the coolant problem i have no clue also where can i get the clips for the top that the bolts go into its missing a few havent taken the top off yet to see what they are like and where can i get the transfer case shifter extension for a 3 inch body lift
thanks for any help or advice given
Old Aug 31, 2010 | 08:37 AM
O-B's Avatar
O-B
Coolant leak may be from leaky intake manifold.
