Crew Cab 4X4 Conversion
Old Aug 30, 2010 | 05:11 PM
714x4's Avatar
714x4
How hard would it be to make a 75 crew cab 2wd into a 4x4, using a 74 highboy running gear?
Thanks, Seth
Old Aug 30, 2010 | 07:45 PM
teds74ford's Avatar
teds74ford
Not bad, if you can weld. I converted a truck, and am going to convert my crew also, but no 4wd conversion is a true bolt on.
Old Aug 30, 2010 | 08:28 PM
714x4's Avatar
714x4
What did you have to change? just t case mount, front axle mount, and driveshafts? What did you have to modify for the steering? and also are the frames different widths for mounting axles?
Old Aug 31, 2010 | 06:37 AM
teds74ford's Avatar
teds74ford
Well, I am still learning about the crewcabs, but I think the frames are the same as the highboys, so in that regard you are in luck. You have nailed down the high points of the conversion. However, I found out that the devil's in the details. Here's what I mean:
You rip out the front suspension, but couldn't unbolt the brake lines, so one gets broke off in the caliper. Off to the parts store for a caliper. Maybe should just redo the brakes? WHile you have it apart, why not put new suspension bushing in too? Oh, that transfer case is leaking. It sure would be easier to reseal it when it isn't under the truck.
Get my drift?
Old Aug 31, 2010 | 09:59 PM
lostinfords's Avatar
lostinfords
major change depending on the yr of the crew frame...my 77 has a high boy frame ..my 78 has the 78/79 frame w/ the fwd and aft fuel tanks, the pwr steering set up that is not the pwr assist and the married transfer case...in my opinion go w/ the 78/79 4wd set up, easiest thing is to add the front clip to your existing frame or swap the 2wd over to a 4wd frame.......2wd steering is behind the axle.. front x member is different and transfer case mount x member along w/ front suspension as well as the steering set up to name a few things...
