Brake line lenght question
Old Aug 30, 2010 | 04:46 PM
santi2322's Avatar
santi2322
So I ran my new brake lines but had a question. If I got a new prop valve and run from my master cylinder to the prop valve, then run the lines from the prop valve to each of the front brakes, do these lines need to be the same length still??? I don't know if I got much room to do that with on my drivers side now.
Thanks
Old Aug 30, 2010 | 07:15 PM
jowilker's Avatar
jowilker
Thanks
I don't think length is critical, you run how you best can get through the obstacles.
I have never read here where length was important.
John
Old Aug 30, 2010 | 10:06 PM
OldHarley's Avatar
OldHarley
I have always said that length is not important!
Old Aug 31, 2010 | 08:17 AM
santi2322's Avatar
santi2322
So what's the reasoning behind the twisting of the line from the master cylinder to the prop valve or junction block usually? I have seen this on many cars and trucks.
Old Aug 31, 2010 | 08:44 AM
OldHarley's Avatar
OldHarley
'Twisting' allows for vibration/stress compensation that otherwise would break a straight run of tubing.
Number of twists do not matter, usually a couple, and are generally based on amount of tubing length you have available, as it normally comes already flared with fittings, but straight, if you buy at auto store.
