Why do I have such bad turbo lag?
01 Excursion 4X4 7.3. I bought it in March and I am the second owner. It has 150,000 miles. When I got it, I noticed it seemed to have more turbo lag than my previous 03 F250. I bought a used Superchips 1705 and set it on the perf tow setting. Ran the codes and got an ICP code. It had oil in the connector so I replaced it and installed a 6637 kit. I have driven it this way for about 5,000 miles. Havent towed with it until i get gauges. All of the intercooler boots are tight and do not appear to leak and the up pipes have no soot around them. Full throttle produces a light haze of smoke. I had the same tuner on the 03 and it is about the same smoke wise. The issue is boost comes on like a light switch from a dead stop. If I punch it, it will barely accelerate and then the turbo will light and it pulls like I think it should. Driving down the road and it has almost no lag. Just from a low rpm to full throttle. The EBPV tube doesnt show signs of leakage. It runs good and gets good mileage, it just seems to have more lag than I think it should. Any ideas? Should I be able to punch it from a stop and at least spin the tires? Not wanting to, but it isnt even close to being able to.
Turbo is original. I bought it from the original owner locally. Lady went through a divorce and was awarded the X. She didnt need it because she was awarded a boat also and she sold it too. Ex husband probably isnt too happy. I have all of the service receipts. It runs good, just not as good as my 03 did with the same mods. I will know more when I get gauges. It just has been a few years since I drove a 7.3 and wasnt sure if this lag is normal and I had just forgotten it was there on my 03. Regardless, I plan on adding more mods in the future. Right off of the bat, I had to do water pump and thermostat housing, tires, rotors and pads all around, X codes and F350 blocks and an ICP sensor. Next is shocks, steering stabilizer, 4" exhaust, and gauges. I am taking as much as the wife will give. So, it is in stages....
cg_wilson2003
12-30-2014 12:44 PM
lilshoe4me
07-02-2014 07:30 PM
roaringford
08-20-2009 03:56 PM
