Temp rattle-can interior resto?
Old Aug 30, 2010 | 12:31 AM
alhauger's Avatar
alhauger
My 86' interior is in pretty decent shape minus the dash pad and door panels. (thanks texas summers!) I was considering doing a direct to plastic primer and some spray paint on the plastic parts of the door panels until i can afford a decent resto job. Any success stories using a similar method or suggestions? I know i'm bound to lose a bit of the original texture, but i think i can deal. Thanks guys.
Old Aug 30, 2010 | 12:51 AM
IntheTrees's Avatar
IntheTrees
About 2 years ago I painted my dash top and door panels with rubberized rocker paint. It has held up really well and looks ok for a truck. It goes on pretty thick and has a bit of texture which helps hide scratches.
The rest of the dash and anything hard plastic was painted with Krylon for plastic satin black. It has held up well too. It looked too shiny when I first sprayed it but has since faded to the satin finish I wanted.
Old Aug 30, 2010 | 01:10 AM
alhauger's Avatar
alhauger
Oooo. rubberized, good call sir! Think i may try the same approach. Hope krylon makes something a bit flatter than satin finish.
Old Aug 30, 2010 | 03:03 AM
panman65's Avatar
panman65
what ever you use clean the heck out of the dash first or as i found out ya get to paint it twice lol
Old Aug 30, 2010 | 03:54 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Surface prep and Cleanliness is 95% of a paint job!
The better it's prepared the better the end result ...
-Enjoy
fh : )_~
Old Aug 30, 2010 | 09:39 AM
nolan62's Avatar
nolan62
I used Duplicolor's Vinyl paint on my dash, trim and door panels. They look great and it's not going to peel off. I also used Duplicolor's Prep Spray first. Follow the instructions.
Old Aug 30, 2010 | 04:09 PM
alhauger's Avatar
alhauger
Great advice guys, thanks. Ill do some shopping around and get to work. Ill let you know how it turns out.
5thwheel-in
Aug 30, 2011 11:20 AM
Telly899
Apr 10, 2011 04:06 PM
xirxious
Sep 10, 2010 12:25 PM
reamer
1997 - 2003 F150
Jan 27, 2007 01:08 PM
benz302
Paint & Bodywork
Apr 30, 2003 07:58 AM
