Engine hesitates
the engine seems to hesitate, and sometimes has a "slight"
hickup in it running, similar to being out of time but it doesnt hickup very bad or consistantly,like a slight studder once or twice. the main problem is that the engine will gain high RPM,s and have a low speed, most times it will increase in performance as the speed gets higher. It will regain almost normal RPM/speed output.
I was told to check the fuel pressure regulator?
I have metered the injectors and listened to them via stethascope.Ok
Previouse owner replaced recently, fuel pump,fuel filter, plugs wires,crankshaft position sensor, EDIS module.
Vehicle had a intermitten starting problem noticable on inclines, EEC power relay was at fault, replaced.
Thanks, The Newbie
