ignition coil
Old Feb 17, 2003 | 06:21 PM
justin reeves's Avatar
justin reeves
ignition coil
I have a 92 ford explorer 4.0 (vin X)4WD I have done the "secondary coil test" as mentioned in the chilton, but am getting no resistance reading at all, Chilton says it should get some reading from between the 3 input wires to the corrosponding plug wire outputs, but I get nothing, should this be replaced.? Or is the Chilton incorrect.
