Modular V10 (6.8l)
camshaft sensor or not?
Old Aug 28, 2010 | 09:10 PM
78bigugly's Avatar
78bigugly
Exclamation camshaft sensor or not?
hi, i have a friend who has a 2000 excursion 10cyl. she says the rpms are jumping from around 600 to 2k or so, at ramdom while driving. took it to auto zone and had it put on computer. they said it was a camshaft sensor, that was changed and still with same problem, was told it may be the wiring or something to do with the timing belt. has any one experienced this or may know what it could be, without having to shell out big buck's on the process of illimination.
Old Aug 28, 2010 | 09:23 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Moved to the V10 forum...
Old Aug 29, 2010 | 08:56 AM
krewat's Avatar
krewat
There is no "timing belt" it's a full chain.
What was the code?
Is the RPM jumping to 2K while idling? If so, it could be the IAC.
Old Aug 29, 2010 | 09:50 AM
78bigugly's Avatar
78bigugly
thanks, im not sure. im going to look at it later, ust going off of what was told.
