Ignition problem help!!!!
Old Aug 28, 2010 | 06:51 PM
fireeater91's Avatar
fireeater91
I have a 99psd that won't start without jumping the Solenoid on the passenger side next to battery. I changed the ignition switch underneath the steering colum but that didn't work. I used to have to pull the shifter toward my left and it would start but now it won't. I tried it in neutral and nothing either. I checked and moved all the wires that i can get to under the steering colum as well. Oh and also checked my relays. I give up, need some advice. Thanks
Old Aug 28, 2010 | 07:06 PM
riverrat41's Avatar
riverrat41
Not exactly sure so I will wait until more read this......Bump
Old Aug 28, 2010 | 07:52 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Heres your Diagram for your starting circuit. from the looks of it, it could be your selector switch or your relay.
http://arrc.epnet.com/autoasp/framerq.asp
user name - marshall
password - public
Select - ARRC, then year, vihicle make, then vihicle type, Diesel, wire diagrams, starting/charging, Then Starting/Charging Starting Circuit [7.3L]
Old Aug 28, 2010 | 08:10 PM
mikeyc0120's Avatar
mikeyc0120
I would agree with Rich. I heard the selector switch is a common problem in certain models.
Old Aug 28, 2010 | 09:12 PM
fireeater91
Ok sounds good ill check the switch tommorrow. It's called the neutral safety switch correct? I found on online for 31.
Old Aug 28, 2010 | 10:07 PM
mikeyc0120's Avatar
mikeyc0120
Yes sir that'd be the one.
FORDMON69
Dec 1, 2005 07:08 PM
Illuminatrix1
Bronco II
Mar 31, 2005 08:21 PM
Tricky Dick
Feb 12, 2004 08:08 PM
BadCompany
Dec 21, 2003 08:47 PM
bowez
Apr 18, 2003 01:32 PM
