Sponsored by: Real Truck
PLAY R FRONT AXLE
Old Aug 27, 2010 | 08:49 PM
rinoturd's Avatar
rinoturd
Unhappy PLAY R FRONT AXLE
I NOTICED PLAY IN MY PASSENGER SIDE FRONT AXLE STUB TODAY WHEN ROTATING THE TIRES. IT IS DEFINATELY THE AXLE TRAVELING THROUGH THE CV JOINTS NOT THE BALL JOINTS OR TIE RODS. I RECENTLY DID THE BALL JOINTS X 1YR. DO YOU THINK I JUST NEED NEW FRONT HUB ASSEMBLIES OR ALSO THE AXLES? THE PLAY IS ONLY ABOUT 1/4"TOP TO BOTTOM WITH THE TIRES ON. THERE ISNT ANY BEARING NOISE THAT I CAN TELL OVER THE DIESEL. LITTLE BIT OF STEERING WANDER. THE SEALS LOOK GOOD AND THE PARTS LOOKED LIKE INSTALLED CORRECTLY FROM THE BALL JOINTS. ANY HELP WOULD BE GREAT.
Old Aug 27, 2010 | 10:31 PM
Pinky Demon's Avatar
Pinky Demon
There are no CV joints on these trucks...
Old Aug 28, 2010 | 07:03 AM
senix's Avatar
senix
sounds like a hub bearing issue to me then.
You need to pull it off and inspect.
senix's Avatar
senix
BTW...you have u-joints.
Old Aug 28, 2010 | 10:16 AM
rinoturd's Avatar
rinoturd
Red face
Thanks for the reply. I took off the hub assembly and it seems ok no unusual play or obviously bad needle bearing. No brake rotor wear from the play. I was going to put on a new hub assembly today. I just wasn't sure how to tell if the axle was bad and needed replaced. All the seals are intact and look in good shape. Mike
