Dorman Fuel Line connectors
The pic didnt work but i fixed my fuel lines by buying the correct two sided barb "Dorman" and using EFI hose from auto zone " its goodyear hose with a blue liner inside and EFI hose clamps " smooth ones". make sure you use the proper size clamps!! I did this procedure because i had to reroute all my fuel lines due to Header clearance Issues. If you do use the OEM nylon hose in order to get the barb on, Ford recommends to Boil some water and place the hose end in for 1 minute and then you will need a special crimping tool to complete the connection. To me this is a PITA way to do it Hope this helps
BigLar
BigLar
DB429SCJ
06-20-2016 10:30 PM
78 PEB
11-17-2015 12:00 AM
wreckhaul
13
01-14-2007 01:51 AM
