Missing Helper Springs
Old Aug 27, 2010 | 11:15 AM
Sparkplugless's Avatar
Sparkplugless
Do all SDs come with helper springs? Mine has none, why would someone remove them? I'm guessing air bags, I assume it was used for towing a 5th wheel, as the rails are still there.
If that is the only reason you all can think of as well, would it make the most sense to install another as opposed to replacing the helpers? Or is it no big deal to leave it as is?
As always "thank you for your support"
Old Aug 27, 2010 | 11:22 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Every F350 I've seen has helpers springs but not all F250s do. I think the helpers are normally removed when airbags are installed.
Old Aug 27, 2010 | 11:47 AM
thomabb's Avatar
thomabb
I think the helper springs were an option on the F250 in '99.
Old Aug 27, 2010 | 12:06 PM
Sparkplugless
Mine is an F350 Dual Rear Wheel. Seems like it oughta have some.
Old Aug 27, 2010 | 12:29 PM
Sparkplugless
Hello Clay, I believe I need to order a CPS from you. And I guess while I have you on the phone, I'll need... (originally by 00 Dave)
a Pacbrake air spring system, and um an A&E, and let's see, a stainless MBRP exhaust system, and how about a 38R just for good measure
Old Aug 27, 2010 | 12:40 PM
mikeyc0120's Avatar
mikeyc0120
I had to remove my f350 helper spring and block to install a lift kit per its instructions. So that is also a possibility.
Old Aug 27, 2010 | 12:44 PM
Franko72's Avatar
Franko72
Molon Labe
It was an option on the 250's I owned two, one with (gas), one without.(diesel)
It was also an option on the 350's IIRC it was part of a camper package.
My 99 350 DRW has them, my bosses 01 f350 DRW does not.
Old Aug 27, 2010 | 12:57 PM
rat49f6's Avatar
rat49f6
Howard I have a set with only 50k on them if u want them they are urs
Old Aug 27, 2010 | 02:32 PM
thomabb's Avatar
thomabb
It's definitely worth having those overload springs. I've heard them slap the stops going through a dip with a load a couple times. I wouldn't take mine off.
Old Aug 27, 2010 | 02:51 PM
Sparkplugless
Wow Thanks Jim, awesome offer. Also I don't even have the stops on mine, so I would have to find those as well.
If I decide to get airbags, would I have to remove them? I can't tell by looking at the pictures I've seen.
Why did you remove yours Jim?
Old Aug 27, 2010 | 08:20 PM
rat49f6's Avatar
rat49f6
as of November 1st you can have the stops also
i took them off when i did the drop on my truck
im pretty sure u can have air bags and overloads ... the bags mount on the spring perch tops so i should not matter
if it doesnt work id be willing to help u make a mount so that they will, im currently engineering a mount for a used system a friend bought
Old Oct 20, 2010 | 09:10 AM
rat49f6's Avatar
rat49f6
Howard I'm gonna be on Boonsville, NY for Thanksgiving i can bring those springs and stops with me
Old Nov 26, 2010 | 06:15 PM
Sparkplugless
Big Reps to Jim, he gave me the springs and wouldn't take anything for them. Not even dinner , maybe another time, he wanted to get on the road.
Thanks Jim! I really appreciate it.
Old Nov 26, 2010 | 08:58 PM
rat49f6's Avatar
rat49f6
dont mention it you would have done the same for me brother
ill get those stops off and bring them with next time
f150crewcab
Jun 7, 2012 09:15 AM
driller tom
2004 - 2008 F150
Sep 6, 2011 06:53 PM
Lonzom10
All Things Towing
23
Jul 1, 2011 01:12 PM
dtpatt2
All Things Towing
Jul 24, 2003 01:30 PM
1w_racer
All Things Towing
Sep 26, 2002 05:08 AM
